21" Inch Coming down to the wire.... tire replacement
What 21" tire service should I get
  • Total voters
    38
Good timing to get in on those R3X-style 20s soonish is offering. With the right tire choice in XL 275/60R20 you may not loose much range, if at all. Durability. Ride quality. Efficiency. All in one. Plus, options in dedicated snow tires, should you ever need it.
VandalSibs
VandalSibs
Andrew
Eastern Washington State
www.sibulskymusic.com
R1T Dual Motor Large Pack
But seriously, get away from those 21s. 20 is where its at! You go from 2 not great options to indecision paralysis over the volume of options between manufacturers, size, type, etc.
It would be nice to be able to do that right now, but it's not in the budget.
Kitsap, WA
FWIW you essentially get a $500 discount on the MSWs by pairing with the Goodyears over the 21" Michelins. By your second set of tires that's $1000 off, and then you're in the black on the 3rd set.
But if sticking to 21s, go Michelin.
forestwalker
Forest
Battle Ground, WA
2023 R1S
Ops Manager - Diesel Repair
If you're strictly factoring cost and efficiency, the price/data are the best indicators, obviously.
-BUT-
If you're looking for colloquial input from users, I cannot recommend highly enough, the Yokohama Geolandar A/T4 275/55 R21 116H XL BSW.
They have been the best mix of low noise, good dry weather grip, excellent in snow, properly rated for the weight, great looking tire I have found available for these on the 21" wheels. I have NO idea on efficiency hit, as it isn't a concern of mine at all, but otherwise, they have been excellent.
VandalSibs
VandalSibs
Andrew
Just for my future reference (if I do end up going with 20" wheels in the future), what are "MSWs" in this context? And is there a good All-Season version of the Goodyears (or some other alternate AS tire that you might recommend?)
-BUT-
I'm hoping to stick with All-Seasons - I'm not doing any serious enough off-roading for AT tires.
Kitsap, WA
https://www.discounttire.com/buy-wheels/msw-type-52
I'm partial to Goodyear for the 25% discount through USAA lol. So I was looking at these for my AS when Pirellis kick the can:
https://www.goodyear.com/en-us/tires/wrangler-territory-ht_NA-255787?tireFinder=true&isPLP=true
VandalSibs
VandalSibs
Andrew
mkhuffman
I am nearing 4/32 on my OEM 21” Pirellis and bought limited remaining stock of the Hankook ION HT. I am trusting Gemini which states that reduced rolling resistance will more than compensate for the increased weight of the tires due to the longer tread life. I hope my experience is the same as others who have posted.
Some LLMs are better than others, and yours seems to understand logic and reason. Rolling resistance IS the most important factor regarding tire efficiency. Period. Weight matters, but not as much.
Get the Hankooks!
KvonBCO
Kirk
Fort Collins, CO
R1T, Hyundai Kona EV, Subaru Outback
I switched to the Michelin’s about 8 months ago. Negligible effect on range, if any, and they are wearing waaaaaay better than the Perelli’s. They seem quieter, though the noise never bothered me and they were good in the snow as wel
jrmbadger
R1S (Gen 1)
I have the Hankook Ion tires for my Model Y and we like them. They are holding up well after the factory set was replaced just over a year after we bought it. Seem a bit more efficient too.
Ironcitijc
New Hampshire
2023 Performance DM R1T Max Pack, Mercedes-Benz GLC 350e
Joined the Hankook tire club today after 24k miles on the original Pirelli 21's. Over those 24k miles my average efficiency is 2.53 mi/kwh. This summer over the last 2k miles I was averaging 2.73 mi/kwh which is more or less what I've averaged over the summer months since I purchased my R1T in November 2023. The cold weather in NH in the winter has a meaningful impact on efficiency for me.
I will share my efficiency on the Hankook's after I get some mileage on them but I suspect it will be a little worse given some of the info already shared on this forum. I paid $295/tire, which I thought was pretty good.
mkhuffman
I am very interested to see how they work for you. Of course when new, they will be less efficient until they wear in. When I put iONs on my Mach-e, I measured a significant improvement in efficiency. My guess is these will be as good as OEM in the long run. Although I have seen posts like you have that suggest they will be worse.
Let us k now how it goes with your tires!
Jamuso
Joe
CT
Ridgeline
Sr software engineer - manager
I replaced my factory 21’s with the bridgestone alenzas. 1st set thru tire rack mobile install were sent back due to not being able to get them balanced. Replacement done thru local installer much better - they did forced road balancing to make sure it was good. So far at 680 miles 2.44 miles/KWH at an average of 37 mph. I do like them. Quiet and nice ride. One comment I got about the michelins was their compound seems soft for the weight of the r1t which might lead to more tire wear. No they weren’t selling me a brand new- that was the comment after twlling them what is was considering.
VandalSibs
VandalSibs
Andrew
Ended up getting the Hankooks installed today - the cost savings over the Michelins won me over in the end.
I'll be tracking how efficient they are over the next few weeks and months and report in.
