Rural1T
Hack to get the wipers out from under the hood so they don't freeze and it's easier to clean out snow from the hole: Service menu > Wiper change mode. Parks the wipers on the glass and you can lift the blades. Note the frunk will not open in this mode.We only park outside - though doesn't get as cold here (STL) typically as it does for you. In the time we have had our Rivian's have not seen anything like you describe, though a bunch of other things to watch out for:
- The frunk becomes a no-go zone in winter, without using a credit card to cut between the rubber seal and plastic tub surround - it ices up, and prevents the funk opening - our R1T actually put visible divots in the hood last year trying to open when iced up.
- Need to set the mirrors to not auto retract when locking - they will freeze closed otherwise.
- Cant pull the windscreen wipers off the screen due to where they are positioned when 'retracted' - so sometimes some water is required to help free them.
- On the R1T the tonneau cover seal will freeze to the tailgate trim, so care is required when opening.
- Brake blending to support regen is really useful - otherwise the drive will be super inconsistent until the motors and battery are up to heat.
We are seeing some charging issues with our Gen2 Max pack battery (super slow charging) - that i think is cold related, but too early to tell.
This has been so useful this winter that I sent Rivian a suggestion to have a user selectable "Winter Mode" for the wipers that parks them in the up position by default. If anyone else thinks this would be useful, please suggest it to Rivian as well.
