Only if a problem occurred—and after investigation—your use of an unsanctioned adapter is discovered and found to be complicit in or the cause of damages.Will using a non-Rivian adapter void warranty? I am sure A2Z is a quality product, but....
Sadly, there are pictures of my use, so they have ammunition
usually what I’ve seen is if you plug in at low SOC say 10% you will get 217kw sustained up to like 40% before it starts to dip, and this is because the battery takes in a lot of heat so it starts to taper early.I did a few posts up . I agree that it seems like Rivian might have opened up the charging curve some? Or maybe the battery was cool enough to allow for that charging rate.
No, but I will accept bribes.
cool color. and thank you for not blocking a second Tesla stall. I do note that you have blcked a Level 2 Chargepoint stall, but tgose have longer cables and are probably able to service a vehicle parked in a nearby stall.
Blocking a stall here is usually a non-issue....cool color. and thank you for not blocking a second Tesla stall. I do note that you have blcked a Level 2 Chargepoint stall, but tgose have longer cables and are probably able to service a vehicle parked in a nearby stall.
fun times.
I've also sent a message to the property owner that they should swap those pay to use 6.3kw chargepoints out with pay vacuum cleaners. They'd get way more use.cool color. and thank you for not blocking a second Tesla stall. I do note that you have blcked a Level 2 Chargepoint stall, but tgose have longer cables and are probably able to service a vehicle parked in a nearby stall.
fun times.
80 kW at 80%.I have never hit 217kw charging on any charger even if it’s 350 rated best I see is 153 ish, I am curious how long did it stay at 217 bc when I charge as soon as it hits 60% it drops down then again at 70 and 80 so what were the step down levels as you were charging. Example if at 80% it was still pushing 150 that would be huge, I often see it drop to 80kw at 80%
80 kW at 80%.
Some more testing at a different location with high state of charge upon arrival.
Adapter is working as expected. No issues to report.
I recently consistently (three days in a row) hit 216kW peak at two differents RANs in MD/VA. I had posted the attached screenshot in Tezlab app as well, if you are interested.I have never hit 217kw charging on any charger even if it’s 350 rated best I see is 153 ish, I am curious how long did it stay at 217 bc when I charge as soon as it hits 60% it drops down then again at 70 and 80 so what were the step down levels as you were charging. Example if at 80% it was still pushing 150 that would be huge, I often see it drop to 80kw at 80%
Correction, 1000V. There might have been some confusion with volts and amps.I spoke to A2Z EV today about the DCFC NACS extension cord and they confirmed the NACS DC 500v cable is still under design/development/testing and we should expect to see it available towards the end of summer.
They are having to spend lots of time engineering a cable that can handle the voltage / amperage from Superchargers while maintaining safe thermal thresholds. Keep in mind the NACS supercharger plug is normally liquid cooled to keep temperatures low.
Hopefully @A2ZEV can share more information as they get closer to launching this new product. I look forward to buying one and performing some testing for the forum.
