jedinight
The website still allows you to order. I tried reordering and got canceled again.. saving people time if they were gonna retry
Sam's Club also carries the tires and might be cheaper for the replacement. You also get lifetime rotation and balance. My local Sam's has and will work on Rivians and will only use a specific lift due to the weight. I'm personally waiting for the 21" Defender option that is suppose to come out this summer and hope CostCo carries it.I’m getting new 21” Pirellis through Rivian SC soon and they are not cheap. Made it to 20K miles, though.
Interesting. Can you say how much the SC charges for the 21” tire? I was considering Discount Tire but wanted to shop around.I’m getting new 21” Pirellis through Rivian SC soon and they are not cheap. Made it to 20K miles, though.
For the 4 tires and installation labor it’s just over $1,900.Interesting. Can you say how much the SC charges for the 21” tire? I was considering Discount Tire but wanted to shop around.
Any updates on the possible date?Sam's Club also carries the tires and might be cheaper for the replacement. You also get lifetime rotation and balance. My local Sam's has and will work on Rivians and will only use a specific lift due to the weight. I'm personally waiting for the 21" Defender option that is suppose to come out this summer and hope CostCo carries it.
Thank you! That’s comparable or maybe slightly better than discount tire I think.For the 4 tires and installation labor it’s just over $1,900.
July 2024Any updates on the possible date?
I"m picking up the Aw09 from atomic wheels next week and decided to get the General grabber HTS 60 instead of the Michilen defender like yours. They both have the same load rating of 116 and max psi at 51 according to the specs. What Psi are you running with yours?Some efficiency notes on the Michelin Defender LTC M/S2 tires compared to OEM 21" Pirelli AS:
So far, anecdotally, I am seeing about a .2mi/kwh decrease on my normal commute going to the Michelin from OEM Pirelli. This is not a result of scientific testing, and weather may be a factor still. Additionally, I have reason to believe that at least some of the difference is due to my wheel choice AW10 wheels from Atomic, having a slightly more aggressive width.
My commute is 26 miles each way, with about 20 of those miles on the interstate. My house is about 500ft higher than work, so my efficiency going to work is almost always higher than returning. The reason I think the offset is the primary factor is that low speed efficiency seems to be the same or even better, but at 75mph on the interstate it has been lower so far. I attribute this to the very slight changes in aerodynamic profile. The difference is roughly equivalent to what you lose/gain with the aero covers.
I do plan on doing a 100mi out and back on the interstate at some point to test this theory and compare my observed efficiency against what I have recorded from the 21" OEM. If there's someone out there in North SATX who still has OEM 21s and wants to meet to drive the same route together and compare, I'd be happy to work on that.
Again, anecdotal observations, but I've had enough trips to start comparing. I'm pleased with the outcome because the wheels look so much better, ride is as good or better, wet handling seems better, and tread life should be significantly improved. Also the Defenders are likely far more capable off-road. The trade off is worth it, for me.
That's actually a lot better than I thought it would be.For the 4 tires and installation labor it’s just over $1,900.
FWIW Discount Tire was going to cost hundreds more. The tire and install would both be more expensive.That's actually a lot better than I thought it would be.
If my tires end up going bald before the Michelin comes out, I'll likely go that route. Much lower chance of them screwing up my truck vs a random tire shop (no Discount Tire in New England).
Same price - 1900 before taxes:FWIW Discount Tire was going to cost hundreds more. The tire and install would both be more expensive.
