Starting Car Noise
chanuvarma
chanuvarma
Chanu
Woodlands
Mine is 2023 R1S, do I have to be worried? I never heard sounds like this in Tesla and that's why I am concerned
Redline
Edina, MN
You can always make a ticket and upload a video with it.
iansriv
Mine is a 23 and it doesn't make that noise. Not saying it's not normal. I'd call it in.
SPITmadFIRE
2024 R1S PDM Max Pack 20" AT
2024 R1S and I get similar AC noises, turn off the AC and it'll stop. This only happens when the vehicle is parked and warm as far as I can tell which makes sense as there's no airflow through the heat exchanger.
DaveA
The AC compressors on these trucks only sound like that after a long fast charge or 100 degree plus temps. I’d get it looked at.
Jimbydude
James
Rivian R1T, 2018 Tesla Model 3, 2016 Honda Civic
Like others said, sounds like your A/C and is normal. Turn it off and check
That doesn't sound normal to me. Granted I've got R1T but if it made that noise i would open a ticket.
JWreck
Josh
R1S (pre-ordered, Audi RS5 Sportback
I’d normally say it’s the AC compressor but usually they’re a little bit higher pitched - it almost sounds like the air suspension compressor but I would still open the ticket.
Even if it is the AC compressor - it’s been an ongoing thing that these cars AC compressors are loud af.
Tr4ckD4ys
Noneya, NY
Mine sounds like that too. With this truck, more so than with other vehicles, I’ve chosen to not worry about anything until the truck gives me a warning light.
Upland
Westwood, MA
Attorney
sounds like my 2022 R1T. AC noise I think. As others have said, any vehicle makes noise and as long as you do not have any warning lights I wouldn't worry about it. Just enjoy the vehicle..
chanuvarma
chanuvarma
Chanu
Woodlands
Ok, But, you recommend not to raise a ticket and get it checked?
electruck
Dallas, TX
2023 Rivian R1S
If the cabin AC is working fine and there are no BMS warning messages, I would not open a ticket just for this. The volume may be louder than you expect but there is nothing there that sounds like it requires service.
If you're worried about this, you're in for a real treat when the radiator fan kicks into high this summer.
mkc1378
Min
Chicago, IL
I can't tell from the video how loud it is, but it sounds like the ac compressor working. I did have an issue where the ac compressor noise was really loud by the passenger area and I brought it in for service. It turned out there was a loose wire next to the compressor causing the racket. So, just take it in for service and they'll let you know if its normal or not.
