ksurfier
R1SQM, Tesla
Only point is that you can get 99.99% the same tire and save a lot of weight…it’s an EV after all and avoiding the heaviest tires is always good from a handling and performance perspective, that’s why all OEM tires and between 35-50 pounds.
Some people are actually getting the on road tires which can net nearly 3 mi/kwh.
Best of both worlds is having two sets, one off road set in mid 50#s and on road set in high 30 to low 40#s, to each their own, but I would definitely want max range when going adventure/offroading…
Desiboy
Tesla Plaid, LR4 ‘11, R1S
Has anyone fit 35’s on the oem 20’s?
35x11.5x20 or 295/65/20. Looking for more off road ability and not really cocorned with range as I have a second set of the factory 21’s. The factory 20’s are all beat up after 2 off road trips with little tears in the sidewalls.
I have 285/65/20 BFG KO2s on my wheels. have had them for 8 months or so, do some offroading, accessing remote hiking trailheads, slight hit with range but have not experienced any rubbing.
Not sure of the 295/65/20.
Desiboy
I did that with my LR4, gets tiresome quickly, settled on 33" KO2s all the time for that as well.
Si.LE.R1S
Chad
Las Vegas
‘23 R1S Launch Edition, ‘20 eTron Chronos Edition
@Rexbo
Have the Ram 2363 wheels (same +18 offset as OP, but 8” wide) and picking tires.
Looking at Open Country 35” 11.5” 20 (nearly 295/65/r20). My plan is to use these exclusively for off road (standard or snow mode to get to trailhead, then rally/all-terrain/rock crawl). I’ll switch back to 22” for daily and road trips.
I’ve been using the
20” ATs, but there is simply not enough sidewall to protect the wheels.
Has anyone tried this tire size with the Rams or Hellcat and can definitely say it’s no go? Should I just play it safe and go 285?
krockett
FJ Cruiser
For the register…
I’m running Hankook Dynapro AT2 Xtreme 285/60/20s on 20x9” +40 Atomic Wheels. No rubbing on lowest and softest setting.
SDRivian
Jeremy
San Diego, CA
SE
@Rexbo
I’ve been using the
I think 285/65/20 is the limit for Rivian with zero/minimal rubbing (until aftermarket fenders come along like Jeeps). 295 would be pushing it...it would certainty rub in standard. Even if you use your Rivian almost exclusively for tails and off roading you still have to drive to the trails and back and the the suspension defaults to standard ride height at speed.
kongzero32
Sam
R1T, XC90, Mustang
Sorry @Rexbo, but I had to copy you. Just looked too good. Here is my R1T with 20x9 +18 wheel and stock Perelli all terrains.
The only rubbing I have seen is on low during medium-ish bumps. I have found not using the soft ride setting helps however.
Rivian R1T R1S Tested 35" tires on the R1T - for offroading / overlanding IMG_0575
Rivian R1T R1S Tested 35" tires on the R1T - for offroading / overlanding IMG_0574
Si.LE.R1S
Chad
Las Vegas
Rivian R1T R1S Tested 35" tires on the R1T - for offroading / overlanding IMG_6978
Rivian R1T R1S Tested 35" tires on the R1T - for offroading / overlanding IMG_6977
Rivian R1T R1S Tested 35" tires on the R1T - for offroading / overlanding IMG_6990
@Rexbo have one entry to add.
Ram 2363 20x8” wheels
Toyo Open Country LT295/60 R/T ~50% tread
No rubbing at standard height/stiff suspension on bumps or with full lock. I was able to make it rub once in soft suspension over a decent bump, so it’s possible there could be rubbing in stiff mode if the treads were new as it’s probably pretty close.
I consider this a very specialized setup just for off roading though as the efficiency tanked to 1.8-1.9 @ 65 PSI. It could also be run in Rally mode to the trail head to avoid any chance of rubbing.
Anyone who wants to try this setup should keep in mind that airing up takes a long time to go from 30 psi to 65-70 psi with the small on board compressor (5-6 minutes per tire). Unfortunately, the only other option is to get a tank compressor for a faster option unless you’re willing to schlep along a 12 volt to power a true off roading inflator. The 8” rim and the 295mm/11.6” tire is supposed to hold the bead really well at even lower psi
I want to take it down to 20-25 psi, but the thought of airing back up is nauseating🤢. - may 30 psi is low enough. 🤷🏻‍♂️
