Which magsafe charger would you get?
Chayse
Fred
SE PA
R1T, BMW X5 MC
Has anyone used any of these with a Quadlock case? I have been using the Quadlock cases for a while now and really like them, I have the suction mount in my other cars with charging head. Really curious how the wireless charging is with other chargers. Thanks
LiamJacobs
2025 Rivian R1S, 2018 Chevy Volt
ForestNSea
San Diego
After some research, I got the TWraps MagSafe charger with matching wood finish. Am very happy with it. It seamlessly keeps the phone in position and charges at a good speed.
https://a.co/d/8ynVsk8
I have the this one too and am really happy with it. Looks good and works like a champ. Aesthetically, I like the look and texture of others a little better. I was envisioning my kids using the drawer/bowl as junk storage though. Ha. Made the decision easier.
md2023
New England
Subaru
I have had the Stowncharge and it has generally worked well charging. I am considering a different one because the sliding cover has begun to rattle just a bit (I have an unhealthy low tolerance for rattles).
md2023
New England
Subaru
On Amazon, some of the photos show a wood grain finish, while others do not. Is this a choice/option?
Cortles
Corey
New Jersey
Analyst
The wood grain finish is a vinyl stick on so it appears wood finish to match the interior of your car.
EV Sportline
evsportline.com
Upgrading Electric Vehicles
LiamJacobs
Have a look at ours -
it's dash mounted - not center console....
Made from cnc-cut and formed aluminum (not plastic, not 3d printed)
As rigid as you can get!
actually bolts-on (no tape, no clips, no glue)
includes power wire to tap into fuse panel
https://evsportline.com/collections.../rivian-r1t-r1s-dashboard-magsafe-phone-mount
Just went to install this on my 2025 R1S gen2, there is no fuse block under the panel. Do you have a new guide on how to install?
Oldsmobile_Mike
Manassas Park, VA
FG/FE R1T recv'd 3/31/2023
I build stuff
Another vote for Stowncharge. You might have to get on a waitlist to get one, but it's worth it.
Also make sure to use one of the two approved style of pucks. I went through a whole "ordeal" recently to find ones that would work with my Pixel 8 Pro and also fit in the allotted space. After ordering a half-dozen different models of puck, only the Jsaux ones fit and worked. Although I do wish the cords weren't quite so long (takes lots of wraps to make them fit). ?
Edit: I also like the OpensourceEV Nexgen dash phone mount for clipping my phone to the left-side of steering wheel, if I need to use it while driving.
SPITmadFIRE
2024 R1S PDM Max Pack 20" AT
s00nish or nothing, customer service and support is incredible
Sundar
SG
Austin, TX
2025 R1S Dual Max
Digital Health Strategy & Product
Did you find a solution to this?
LiamJacobs
Not yet, I did call the manufacture, they have a Gen 2 kit being released in the next few weeks and will swap it for me, they were very responsive. Will update when I get the new kit, for now I’m just using it as a MagSafe holder.
Sundar
SG
Austin, TX
2025 R1S Dual Max
I’m trying to wire up some additional hardware and I don’t want to tap odb2 since I think the energy provided is pretty low - could be wrong. I also opened up the “fuse panel” and then realized they had replaced everything with e-fuses.
quartz
Los Angeles, CA
Honda Clarity PHEV
The best solution I found is getting a slim magsafe power bank, and mounting that in a phone holder. This way the car charges the power bank, and the bank is wirelessly charging the phone, even when the car is off.
RivianNC
NC & SC
Lucid Air
