Charging at RV sites?
DeafPug
Kansas
'18 Model 3, '22 R1T
Like @VandalSibs suggested, I really like the route of the Tesla Mobile Connector and the proper pigtail to automatically set the charging amperage. Slightly more expensive than the cheapest route, but it's definitely the easiest setup out there.
In addition to the 5-15 adapter that comes with the Mobile Connector and the TT-30 adapter that was linked, Tesla also has a NEMA Adapter Bundle that supports 5-20, 6-15, 6-20, 6-50, 10-30, 14-30, and 14-50 outlets and includes a convenient storage bag.
beatle
Springfield, VA
+1 to the Tesla UMC and a TT-30 adapter. (I still think it's weird that Tesla doesn't offer a TT-30 adapter of their own). The UMC is very convenient for other types of plugs you may encounter if charging at friends and family that don't have their own hardwired EVSEs.
JM.
Jon
France
Tesla, Energica
I've had both, and still needed either one or two other non-Tesla adapters to cover places that I needed to charge at. So to me, it's not useful to pay for the Tesla solution which isn't a full solution.
VandalSibs
Andrew
Eastern Washington State
www.sibulskymusic.com
R1T Dual Motor Large Pack
Fair enough.
Curious, what other adapters have you needed?
emlo
R1T Dual Max Performance, R1S Tri-Motor
JM.
Jon
France
Tesla, Energica
Fair enough.
I no longer have the Tesla, so I can't recall all of them. One is a 10-50, which is somewhat common with old houses and welders in garages. Obviously the TT-30, and there's one other, I think. Possibly one that was simply perpetually out of stock, I had backorder issues getting some.
HaveBlue
I would not do this. Instead use this adapter with the standard plug included with your mobile charger.
https://a.co/d/ez9rcpb
That will only supply 12A. No adapter needed for that. Just plug into an ordinary outlet at the campground.
Better off with the Parkwood tt30p to 14-50r ev adapter and adjust the car to 24A for twice as much juice.
JM.
Jon
France
Tesla, Energica
Yup, exactly. If I'm charging the EV motorcycle/bike I can just plug into the RV outlets for 12a. And the difference between 12a and 24a is actually more than double due to losses while charging. It's like you're losing a couple amps to losses/maintenance.
Blu2Grn
Paul
Mountain View, CA
R1T Tri-Max, Toyota Venza
Excellent point. Infrastructure at most campgrounds were put in before EVs existed. Even if they have the right outlets, doesn't mean what is unseen is up to snuff.
Fair enough.
Not much of an expert on electrical issues but wonder if anyone has experience charging their R1 at an RV site with 30amp power. If so, what adapter did you use? I thought this might be a solution when up in the Old Station / Hat Creek / Lassen area last weekend but the RV socket was different than the plug on my Rivian supplied portable charger. (Co-pilot responded to my query that The standard RV 30-amp outlet is a TT-30 plug, which provides 120V rather than the 240V that most Level 2 chargers use. To make it work, you’ll need an adapter that converts the TT-30 plug to a NEMA 14-50 or J1772 connection, ensuring it’s wired correctly for EV charging).
Quick word of thanks to all who have replied and offered suggestions. Very helpful.
jd2025
2025 R1S
We have charged our R1T at RV campgrounds a number of times. Many campgrounds have both a 30amp and a 50 amp outlet on the post.
Our Aistream operated on a 30 amp plug. We have been able to plug in the Airstream and the Rivian at the same time. The charging on the Rivian has run at between 13 and 18 mph.
Be careful doing this. My understanding is that the 30 amp uses one of the legs of the 50 amp, so using both the 30 amp and the 50 amp at the same time can seriously overload the shared leg. They are not installed with the intent for them to be used at the same time.
moosetags
SuEllyn & Brian
Santa Rosa Beach, Florida
I am aware of this situation. I will only use both simultaneously if each outlet has its own circuit breaker on the post. I have done this a number of times without any issues, but I carefully monitor the situation.
JM.
Jon
France
Tesla, Energica
I don't know where you got this "understanding" but that would be illegal and very stupid.
JamuJoe
Joseph
Hesperus, CO
RAM 2500, Polestar 2, R1T Max Pack Performance
Retired Petroleum Engineer
I have used a NEMA 14-50 to TT-30 adapter dozens of times in RV parks as we travel with our R1T (dual, max, performance) towing our Airstream. I do set the R1T to 24A, snd have never had a electrical issue or objection from the park owners. Note that I avoid KOA, as many have a no EV charging policy. I have also used the pedestal 30A simultaneously for the Airstream.
theonetruestripes
Josh
VT - North Eastern Kingdom
Tesla Model Y, for a few days before I “swap” it for an R1S
Programmer
The TT-30 can also be used with a ground-neutral bonding plug to charge from a generator
Oh?
What is the process for this? Like say I have a generator with a 30A plug and some 15A plugs as well. What else would I need to use it to charge my Rivian? (say it is a multi-way power outage and I’ve used the Rivian a dozen times to go buy gas or something and now feel like I should charge it up a little...or maybe it is a few months after the outage and I have all this gas that I don’t otherwise use and want to burn it before it gets too much water and can’t be used in the generator...)
