endress14
Grand Cherokee, XC 90 recharge
TBD
if you connect to sunnylink, you can see many more options to toggle (i also have the same staging.sunnypilot.ai). auto lane change is in there along with various options for delays/nudges to initiate the change.
gerrylum
Gerald
Providence Village
Director of Marketing
Guys, how do you download the version of sunnypilot that allows auto lane changes? Gerry, i tried using the branch that you installed in the “DIY Rivian autopilot” video but it wouldnt install (sunnypilot/staging-c3-new). I’ve downloaded the version i found on their sunnypilot website (staging.sunnypilot.ai) and that downloaded and works but it doesnt have a lot of the options that you were using in that video, including auto lane changes.
As mentioned you need to use the Sunnylink dashboard to change a lot of the settings on the Comma 4.
curtisK
Curtis
2024 R1S
Very cool, i signed into sunnnylink and switched it over to auto lane change. It worked so good. My wife was impressed at how smooth it is. So much of an upgrade over rivian adas. The mads is one of my favorite features. I’ll take some pictures of the connections under the footwell this weekend and post in case it helps anyone.
gerrylum
Gerald
Providence Village
MADS is such a cool feature that's so difficult to explain to anyone who hasn't used it before.
krockett
FJ Cruiser
Got the Comma 4 installed, using the Comma provided harness (AXM modified with wago clamp), and Lukas longitudal adapter. Used Gerry’s fuse tap in 33.
Everything powers up with no errors on dash, but not sure if the Comma is working. Connected WiFi and installed openpilot, pressed down on the stalk one time on the freeway and it just enable regular cruise control. Isn’t a display supposed to show up on the Comma and steering/lane centering taking place?
gerrylum
Gerald
Providence Village
The Longitudinal adapter is not compatible with Openpilot. It only works with sunnypilot. If you want to run openpilot, remove the connection to the upgrade.
krockett
FJ Cruiser
Gotcha, let me delete openpilot and get sunnnypilot installed, anything I need to do after pointing it to staging.sunnypilot.ai? Are the settings configured on the Comma or do I need to do something with sunnylink dashboard?
gerrylum
Gerald
Providence Village
Just beware there is a bug right now in Sunnypilot regard2ghe Longitudinal upgrade. Lukas and Sunny wlare actively working on fixing it, though.
There will also be ssvereal settings you'll want to change in the Sunnylink dashboard to take advantage of all the features that the long upgrade enables.
krockett
FJ Cruiser
Is there any recommended list of features that should be enabled? Got sunnylink dashboard pairs, looks like I’m in business. Can’t wait to get this thing calibrated and start playing around.
Curious about what Rivian folk have configured in the Steering and Cruise sections
dekeen
Raleigh, NC
Launch Edition R1S
Is this bug only with Comma 4? I haven’t had any issues with my 3x.
gerrylum
Gerald
Providence Village
It would affect both, but only if you're using the longitudinal upgrade.
dekeen
Raleigh, NC
Launch Edition R1S
Thanks. I am using the Lucas long upgrade, but haven’t experienced any issues. Is it somehow device specific? I am also using the fuse tap for power and the Chung mag mount. Or is the issue only with dev? I’m running release.
SwampNut
Carlos
Peoria AZ
2022 R1T Launch Edition
Geek
Am I the only one who twinges when seeing Lukas' name misspelled?
I believe that the issue is inconsistent, but not sure. Right now I'm kind of checked out, in the stages of grieving because my C4 had a failure and it's out for warranty repair/replacement.
Sigh.
Having to ... drive.
One week ago they said it could take up to one week, so...
Rivian R1T R1S Comma AI Owner Demo Drive Connect Thread incredible-me-will-blowing-you
gerrylum
Gerald
Providence Village
It's not device-specific per se, but if you're on a Comma 3X you may be using the Master branch of Sunnypilot that hasn't had the Panda-over-USB deprecation change merged in yet. If you have a Comma 4 you only have the option of dev or staging, both of which have the aforementioned change merged in which is what is causing the issues.
dekeen
Raleigh, NC
Launch Edition R1S
I have a 3X and am running "release.sunnypilot.ai". Once the Panda-over-USB deprecation change is merged in, will I need to run a data blocker or will there be a change to SunnyPilot to fix it?
