Will R2 have the same heat pump as R1 Gen 2?
R1Skol
Minnesota
2025 R1S
G2 Here with a brand new heat pump. Haven't noticed a difference from original (aka updated heat pump technology) if i keep it at 70 not horribly lound. Set it to hi temp and yes very loud. Going to be -20F next 3 days. Excited to see how well it keeps up.
cusetownusa
Syracuse
Rivian R1S and Telsa Model Y
let us know how it does. Going to be cold here as well but probably not that cold.
harkco
Kevin
2022 R1T LE / 2018 Lexus GX
Gen 1 doesn't have a heat pump. AC only. Heat pumps have to work pretty hard when there is a significant temperature delta.
Yes I realize that. More reason that I love my Gen 1. Listening to that would drive me over the edge.
Manalishi
Larry
Illinois
2025 Rivian R1S, 2021 Mustang Mach-E FE
Software Sales
That assumes you have natural gas. Quite a few areas have very expensive heating oil so a cold weather heat pump saves a lot of money.
also, Nat Gas prices are adjusted with weather - currently in the middle US as we are headed towards record cold tonight, prices are spiking. :(
Time2Roll
2026 R1S Quad - 2001 F150
no = preorder R2
yes = preorder Volvo
Do you want a heat pump? Or just don't want the R1 heat-pump?
I would assume R2 has the pump and it will be sized a bit smaller to better suit the smaller vehicle. Hopefully runs smoother too. Should only be better than the R1.
Otherwise god speed with the Volvo.
iansriv
OK, I want to be clear about my future choices. I don’t have a problem with a heat pump. I had one in my model 3. However, it needs to be whisper quit like my model 3.
All they have to do is hire the guy that designed the M3 system and bob's your uncle.
ksumnole
ksumnole
2025 R1T TriMax
I don’t want the shitty loud heat pump.
ksumnole
ksumnole
2025 R1T TriMax
Or reverse engineer m3 heat pump and copy design.
hammick
Montana
Tesla sales gal called me yesterday and said they had some great deals on the model Y. I told her sorry I can’t drive Tesla‘s anymore. She was very polite and thanked me for my time. I almost felt bad
Dave Cundiff
Dave
Pacific County, Washington
Apparently if you design an electric motor assembly well enough, you can minimize or counteract the vibrations that cause noise.
We have two exterior heat pumps for our house's heating systems. The 2018 heat pump model (rated for temperate environments) is moderately noisy. The 2025 heat pump model (different manufacturer, rated for very cold environments) is very quiet.
If the R1 Gen 2 heat pump otherwise works well, Rivian may have had enough time to design a less noisy but equally effective successor. We will see....
Best wishes!
