krockett
FJ Cruiser
I tested 275/65/20 on 20x9 +25
No steering rub on Lowest.
Just did a static test today with a front tire for brake caliper clearance. Need to relocate wheel balance weights before doing rolling tests.
Will drive the car next week on this rim/tire combo to check bump rubbing on low and lowest.
What wheels are you running, if you don’t mind the ask?
krockett
FJ Cruiser
How about the wheels, not tires. Was wondering what rims have +25. Most non-Rivian specific that I’ve come across with our bolt pattern are +18.
Rexbo
Rexbo
I tested 275/65/20 on 20x9 +25. No steering rub on Lowest.
Thanks! Added to table!
FadedSS
San Diego, CA
'22 Rivian R1T
Looks awesome and I am planning on the same wheels. Do you foresee any rubbing issues with stock size 275 65 20 tires?
For reference, here are some photos of my truck with the Racelines installed and sitting at standard ride height, to be determined how much rubbing there is while offroading but assuming there will be some.
Mark_AZR1T
Gilbert, AZ
jackpucks.com
R1T Launch, R1S Canyon Red
@Mark_AZR1T @EV Sportline since you guys have done lots of testing, any inputs?
Not sure how I missed this, but I did respond on another thread about 35's , Toyo 285's to be exact. With a proper off-set and build of a wheelset, they work well, but in LOW you will absolutely have an occassional rub on compression turns and a hard lock on a driveway. Some people just cannot tolerate any rubbing on plastic, so it's a non-starter for many.
dp351
Ariel Atom, R1T
Rims
https://www.ebay.com/itm/174711737057
Tires
Nokian LT3 Hakka Studded.
Hopefully one of the experts will confirm this, but I believe that these are the first “relatively cheap” wheels with an offset that’s not too different from stock. Very interesting.
Please share photos of these on a Rivian & confirm that they fit over the brakes.
OffRoad987
Henry
Southern California
Rivian R1T , Porsche Cayman
Rims are great.
Towed 6000 lbs on low for 60 miles. No rubbing.
Lowest has some rubbing on sharp turns and bumps.
Usually drive in standard in the snow.
Rivian R1T R1S Tested 35" tires on the R1T - for offroading / overlanding 8BE7168B-2CA8-4F6B-BE8A-8A5B78974204
Rivian R1T R1S Tested 35" tires on the R1T - for offroading / overlanding 71E27580-6AF5-41CE-BEBA-93DD0B041A6B
Rivian R1T R1S Tested 35" tires on the R1T - for offroading / overlanding B840F6F9-FFB6-4A7A-9DC2-1C354EE5C383
Rivian R1T R1S Tested 35" tires on the R1T - for offroading / overlanding 60419AD9-CCF7-4B91-94F9-1F4F165A6326
Rivian R1T R1S Tested 35" tires on the R1T - for offroading / overlanding E06D8CAE-4522-4C48-9A5A-FEEFEC1142F4
Rexbo
Rexbo
Nice! Thanks for the update and looking good!
WSea
Patrick
West seattle
R1T, Outback
Architect
Rims are great.
Running with Texas plates but living in the okanagan?
seanocono
Sean
LA
Tesla Model X Plaid, Tesla Model Y Performance
Truck looks great. Thanks for sharing.
SDRivian
Jeremy
San Diego, CA
SE
Thanks for the great info @Rexbo
Any update on fitment/rubbing now that you've had a chance to put on some miles on your aftermarket setup?
Rexbo
Rexbo
High ride height never rubs even at full compression. The increased spring rate from airbag pressure just doesn't let the front wheels compress as far.
In Normal ride height, and soft setting, it takes a pretty big speedbump/pothole/bump/flex to get the front to rub, but after a while the plastic fenders have self-clearanced to the point where it really isn't an issue anymore. I'm going to experiment with a heat gun and a wood roller on the remainder to see if Its just able to get molded out of the way since the metal fender behind doesn't seem to catch. Honestly I'm pretty happy with the setup now.
In low ride height, it rubs a lot on bumps, and rubs occasionally when turning, but I rarely put it in low except to kneel on parking for the wife.
