12v Lead Acid Battery Replacement
kurtlikevonnegut
SC/TX
2023 R1S DM, Honda Odyssey
FWIW, from a chat I had with SC staff last month it looks like they have hired contractors in some locations to do routine (lower skill) jobs like tire rotations and 12v battery swaps. Hopefully that is keeping the costs down a bit. Might also be that they are absorbing some of the cost as a way of acknowledging this was a design and sourcing flaw. Just my speculation.
I think it's more likely the latter than the former in this case if anything simply because the same SC recently quoted me $300 for a tire rotate and balance.
Rivianero
Brent
San Marcos TX
2022 R1T quad large
My appointment last month was for tire rotation. SC did it for $60.
Tires should not need rebalancing after rotation if already balanced.
mudito
Aldo
I got the notification on Monday that my battery needs to be replaced (32 months, 50k miles) and scheduled an appt for a week from today. Service called me to move up the appt due to urgency and I'm now scheduled for noon tomorrow (hopefully when I leave work today it's not kaput). Quote from service was $419 to replace the battery, which is expensive but not terrible.
Maybe they got feedback from others that the replacement cost is prohibitively expensive.
Most likely that's the price for a single 12v battery vehicle. For dual 12v is double at least.
Tucker74
Tucker
Austin, TX
They have to do a reset via the service menu when you disconnect the 12V, meaning you will need a service appointment even if you replace. And make sure you disconnect the HV at the fireman’s loop 😉
Rivianero
Brent
San Marcos TX
2022 R1T quad large
That is not entirely true.
There are methods to replace the 12v without interrupting 12v power.
Disconnecting the HV does not require a special reset.
Current versions of the software allow resetting 12v errors via the RIDE menu.
Tucker74
Tucker
Austin, TX
Was just going by what the remote tech told me yesterday, I asked him how to get into the service menu and he said it’s a one-time use generated code they get. Not familiar with ride menu, but that’s cool (I watched the whole process so I could do once out of warranty). On the HV, you can totally do by removing the fireman’s loop at the plug … but was warned you really don’t want to not do this 😉
Rivianero
Brent
San Marcos TX
2022 R1T quad large
I have done that a few times with no negative impact. Should be fine unless they changed something in the software. Haven't seen anyone else reporting issues.
Sounds like you mobile tech is taking the approach that customers shouldn't touch anything on the truck
Tucker74
Tucker
Austin, TX
He was nice enough about it, but I’d put this at 🍌🍌 as opposed to a standard battery replacement in an IC car. There are multiple connections at each block that bolts to the battery, he also jumped the positives when connecting to balance L+R load. Not serious wrenching though, my hobby is restoring old Land Cruisers.
Where do I read more on this RIDE interface?
mudito
Aldo
Happy playing around :)
MountainBikeDude
Vancouver
Sojhinn
2019 Tacoma
Teacher
Do you mean that the head is 8 mm and the hole size is actually M5? I am in the process of making an adapter for aftermarket batteries, and want to confirm I didn't make a mistake on my adapter thread size.
mudito
Aldo
I have an M8 nut and threaded in perfectly, if that answer your quesiton 😊
Sojhinn
2019 Tacoma
Teacher
Not really. An M8 nut would thread onto the terminals under the plastic but wouldn't work with the battery terminal.
mudito
Aldo
I didn't remove ANYTHING so I did not thread it on the battery terminal directly.
Sojhinn
2019 Tacoma
Teacher
Glad I checked. As we are discussing two different things. I'm asking about the actual 12v battery terminal connections not the ones rivian adds on top to connect all the modules.
The physical oem battery terminal is an M5 thread hole.
Thank you!
