Any tests done on Vampire battery drain?
Craigins
Chicago Suburbs
Software engineer
I put it into shipping, tire change, and car wash mode. Luckily I am home sick today so I can actually let the truck sit for a day.
does that set it to the lowest suspension?
Engineering, Dog Petting
Max
Nissan Truck
I was once out of the country for over 90 days in a row for work. Car started up fine when I got back. Wasn't an EV though.
I can't leave my wife's 8 year old Subaru sitting as long as I can leave my 19 year old Nissan. So even with ICE it looks like the more tech the more power loss.
So, cameras are still warm in shipping mode after ~23 hours. Truck had some sort of a fan running in the frunk area. It's below freezing out right now, cabin was cold. Unplugged when the truck was at 70%, this morning it was down to 62%. Definitely something wrong with Rivian's software to cause that much vampire drain. Hoping it's just a software regression and fixing it will be easy.
Kitsap, WA
Okay, this is getting out of hand. 8% is huge! Why are the cameras still running if they're disabled? Has anyone done this sort of FLIR test on a Tesla?
The mystery fan has been heard by many, including myself on this chilly morning.
Zybane
Crestone Colorado
Ford Raptor 37
Military Pilot
I am curious about this issue too. I took delivery of my R1T and went on vacation for 8 days and left it unplugged. When I left my range was 150 miles, and when I came back it had decreased all the way down to 28 miles. No gear guard, and no, climate system running as far as I could tell. Anyone else have the same experience?
Whoa that is really bad.
zefram47
Rivian R1T, Alfa Romeo 4C
I sure hope they get this under control and soon. It basically renders leaving the truck at the airport or a trailhead a "really bad idea (TM)", forgetting the calculations someone made suggesting an additional cost of upwards of 2900 kWh/year just sitting parked. For reference, all the driving I've done in my MINI Cooper SE since Feb 2021 is around 2900 kWh or close to 10k miles.
Forager
PNW
Structural Engineer
4% loss per day (seems to be the “best” case at the moment):
.04/day*135kWh*365 Days = 1971 kWh/year
8% loss per day (seems to be a common upper end loss):
.08*135*365 = 3942 kWh/year
In context, the average US home consumes 10,715 kWh/yr. This doesn’t include any charging losses, so add on another 5% and you are well over 2000kWh/year at the low end
https://www.eia.gov/tools/faqs/faq.php?id=97&t=3
zefram47
I was estimating at 6%. But the point stands that 2000-4000 kWh/yr just for the truck to sit still is ridiculous. Another data point... To drive the truck 12k miles at 2.1 mi/kWh is 5700 kWh. That certainly makes the vampire draw look a hell of a lot worse from a cost and efficiency perspective.
jjswan33
Joshua
Sandy, OR
Put another way a R1T with EPA range estimates would do ~2.5 mi/kWh. Based on 12k miles/year that would be 4800 kWh.
Factor in nominal 2000 kWh of parasitic loss and your efficiency drops to 1.76 mi/kWh. If my math is correct that equates to a MPGe of around 50… not great
CommodoreAmiga
INACTIVE
INACTIVE
EPA estimate is 480W/mi (2.083 miles per kW), so 12k miles driven would be 5,760kW. With +2,000kW vampire drain for the year you'd be 7,760kW for 12k miles, or an efficiency of 647W/mi (1.547 miles per kW) -- greater than 35% increase.
I get 70.2 mpg-e using EPA estimate and 52.1 mpg-e including vampire drain.
Odd that we have considerably different miles-per-kilowatt but arrived at similar mpg-e numbers.
jjswan33
Joshua
Sandy, OR
I just took 314 miles of range / 125 kWh usable battery to get the 2.5 mi/kWh
CommodoreAmiga
INACTIVE
INACTIVE
